Embedded vs link .pvz in creo illustrate
jlapointe
In Creo Illustrate there is 2 ways to import a .pvz in a .c3di file: by a link or by embedded means.
Embedded allow to put .pvz without the hassle of linking consequences.
There is a problem when the link method is used, when somebody move the file in a different folder, the links are lost and images in the figures are disappearing. Is there a method to relink everything without redoing the imagery work?
For the embeded solution, is it possible to change for a link solution without redoing the imagery work? I mean I have a .c3di with embeded .pvz that i want to change from embedde solution to linked solution.
2 REPLIES 2
Hi Joel,
Once you have imported the PVZ file, via the embedded option, it is not possible to change it to link.  There is no option available in the Edit Structure > Content, except Delete.
If you import the PVZ via the link option, and the link is broken, you can Unlink or Repair Link.
Amit
Hi Amit,
Sometime, when I tried to use ''Repair Link ‘‘, it is not active (grey ) like in your photo, and I not figured out why ?
Laurentiu
