Is the advanced assy extension (AAX) required to create an external merge feature? A client without AAX can create a regular merge, but the “external” pick is grayed out.
Are you in part or assembly mode? (or in an activated part or an activated subassembly in assembly mode?)
Doug, yes - External Merge / Inheritance require AAX
