Fasteners assembly in BOM
umg
Hello dear members,
Is there a way that Fasteners assembly doent show up in BOM but its members are shown with correct qty?
Let me give an example, suppose 1234 is a Fasteners assembly consist of a bolt+ Nut+ 2Washers. Now I am bringing this assembly into another assembly lets say 5678. In 5678, I am patterning the 1234(assembly) three times, will it be possible in 5678 BOM to show 3bolt+3nut+6washers as individual lines with correct qty, but not to show 1234 fasteners assembly in BOM line of 5678. Thanks.
Chris3
(To:umg)
Not easily no.
If you are referring to a repeat region BOM on the drawing you could write your own relations to try and do sums with your own variables but that is going to get messy.
If you are referring to Windchill BOMs then you would need to manually remove the assembly and manually add in the sub assembly components.
