How do I setup Mfg documents in Creo? (setup sheets, tool drawings etc.)
Anthony,
You can try the process documentation under the applications tab which is relatively easy with the help documentation in Creo. or Create a custom report using report parameters and drawing models that is more difficult to setup.
