How to eliminate the message
hdu
Hi, I am facing an issue here.
When I created a drawing (use the template from my company), a message always occured.
Formart properties(Drawing properties) of the template such as the below:
I just think there are some relations between the message and the options .
And if so, Can I delete the "aux_line_font"  from the tree options?
        Many thanks !
MartinHanak
24-Ruby II
(To:hdu)
to remove aux_line_font 21 SOLID option you have to change aux_line_font 21 SOLID to aux_line_font 21 SOLIDFONT
MH
Martin Hanák
8 REPLIES 8
Mahesh_Sharma
22-Sapphire I
(To:hdu)
There is an article CS20718 regrading the same.
This may help you.
Thank you for your reply !
However, my Basic PTC.com Account have not sufficient privileges to access to the area of eSupport.
Could you deliver the article CS20718 converting pdf  by e-mail ?
thank you very much !!!
Mahesh_Sharma
22-Sapphire I
(To:hdu)
Here is the resolution [art of document.
  • The format references line styles that are not available
  • Remove the references
    • Select File > Drawing Options and change aux_line_font 26 DXFFONT_#  to aux_line_font 26 SOLIDFONT for each font
    • If aux_line_font is listed more than once repeat the same procedure for each entry
    • Two additional aux_line_font options appear to be added but they will go away after updating the drawing
    • Select Add/Change > Apply > Close
    • Select View > Update > All Sheets
then, update
However, I can not change aux_line_font 21 SOLID  to aux_line_font 26 SOLIDFONT,
just add aux_line_font 26 SOLIDFONT options.
I still didn't solve the issue..
Thank you very much all the time !
Mahesh_Sharma
22-Sapphire I
(To:hdu)
OK, try below steps.
1. Open drawing which is prompting specified warning, Change aux_line_font 26 solidfont.
2. Create new drawing and merge affected drawing using Insert > Copy From other Drawing.
Save new drawing and open and check the message. If it is clear you can make changes in new drawing and use that.
I can not change 'aux_line_font 26 solidfont' ,
MartinHanak
24-Ruby II
(To:hdu)
MH
Martin Hanák
I was finally solved it .
Thank you very much for your help,
and also for Mahesh Sharma !
