The PTC Community will be on read only status starting March 23rd in preparation for moving our platform to a new provider. Read more here
How to see errors and warnings when publishing PVZ from Creo Parametric?
M_C_Anderson
When publishing a PVZ file from Creo Parametric, the message log will state something along the lines of:
Publish completed - # Errors # Warnings
When # is not 0, how can I actually read what those errors and/or warnings are? I tried generating a log with the published PVZ, but the resulting log is fairly unhelpful, simply stating what was published, where it was published to, and with which recipe file.
Ah, I found it. The errors are listed in the session log, which for my company's install is in
C:\Users\<USERNAME>\AppData\Local\Temp
 I assume this location will vary. I was able to find the warnings listed out with somewhat helpful descriptions:
2 REPLIES 2
Have you looked at the trail file? I haven't come across this myself but sometimes there is additional information in the trail file.
