How to show bend note in flat view of drawing.
kpaiva
Hello. I am new to Creo and Ive been creating flat patterns using a family table. The bend notes do not show up even though they are turned on in options under sheet metal/bend notes display settings/show bend notes. The tangent bend lines show up however. How do I get the bend notes to show up? Thanks
mbonka
(To:kpaiva)
Hello Kenneth Paiva
welcome to forum. See following picture and notes.
     1. set desired drawing model active
     2+3. show model annotations in desired drawing view
     4. show the model notes
     5. show bend axis
     6. GREEN color --- move your note als you wish (use mouse )
Just a tip:
If you are looking for some functionality (icon) try following:
     1. right up COMMAND SEARCH
Hope it can helps
Regards
Milan
2 REPLIES 2
mbonka
(To:kpaiva)
Hello Kenneth Paiva
     5. show bend axis
Just a tip:
Hope it can helps
Regards
Milan
kpaiva
(To:mbonka)
I had been in that area but didnt know what to click. That worked. Thank you.
