Insert Mode grayed out in Assembly mode
ptc-115314
Anyone have any idea why "Insert Mode" would be grayed out in Assembly Mode?
Edit>Component Operations>Insert Mode<------------------------It's grayed out!!!!
This happens when there is a component highlighted and when nothing is hightlighted....it's always grayed out.....
To answer some of the question I've recieved......I'm working (STILL) in WF 2, build M240
Carrie I.- Are you sure your assembly is active?
The assembly is active...It's the only file open.
Jim T. - do you have a component "active" – like when you are editing it in the assembly?
No, there is no component "Active".....This was the first thing I checked.
Ok, I found the problem.
What I did was opened a Windows Explorer and selected the folder and change the folder and all the files in it to not be read-only. Of course I had to erase everything out of session and open the file again.
I'm not sure which file it was, but evidently one of the files was read-only according to "Windows" which obviously effects Pro/E.
