Insert a group into an assembly
Dale_Rosema
At times we have a foot that is added to an assembly. The foot can have multiple configurations of extensions - leveler A, leveler B, caster A, caster B, .....  Also there are multiple sizes of feet.....
When updating or creating a new generic, is there a way to insert (assemble) a group into an assembly without it becoming a subassembly (would like them to stay individual parts that can be turned on/off in instances). If there are 10 parts with 9 of the parts constrained to the first part, I would like to insert the 10 parts at once constraining the first part to the assembly.
Dale
pausob
(To:Dale_Rosema)
The workflow I use to duplicate groups of components from one assembly to another is
1) activate the source assembly and select the components and/or groups of components
2) copy
3) activate the target assembly and paste-special
4) check this box
5) OK, select the new references; you should not be required to re-specify the constraints between components in the copied group
2 REPLIES 2
pausob
(To:Dale_Rosema)
2) copy
4) check this box
Dale_Rosema
(To:pausob)
After making the parts that I wanted to copy into an assembly, I was able to set the constraints to better suit they insertion in the new assembly. Thanks for showing me how to do this. It will save me a lot of time.
