Internal Framework (AFX) end cap
CW_9587574
7-Bedrock
I'm trying to create internal end caps on a framework assembly I generated using AFX. I'm used to being able to do this in SolidWorks (see documentation) but I can't find the equivalent in Creo - can someone please show me where I'm going wrong? Does this exist in a different menu?
The closest I've found is the 'New Equipment Element', but this only generates external end caps and with a chamfer, not a radius. I'm expecting the tool to grab the radius from the RHS profile definition and able to be set internal/external dynamically.
I've tried setting the 'T' parameter negative to achieve something similar but to no avail.
Any help will be much appreciated, thank you!
7 REPLIES 7
If you uncheck "With chamfer" you can use Round on the corners afterwards, as the generated end cap is a solid. It's a manual operation but returns a nice result.
Ideally though, there should be two options in the end cap generator: "With chamfer" and "With radius".
Hi @CW_9587574 ,
thanks for the input. We are thinking about putting this in one of the next AFX releases.
If you need this in advance or are willing to test it then please contact me directly so we can discuss the details.
Greetings Sam
Samuel Brantner
B&W Software GmbH
Thanks @SamuelBrantner , happy to hear you are working on this already. To be honest I probably don't use framework enough to be a good test subject, but that is also why I thought I was just looking in the wrong menu.
@EdvinTailwind thanks for the suggestion but my main point was I wanted to find a way to create 'internal' end caps, i.e. those that exist wholly within the profile, which in this case would have also necessitated a radius. Adding a radius to an external end cap would not produce the desired result.
Is it possible for the users to create their own master models and add them to the AFX structure like we can with IFX?
Hi  @BenLoosli ,
AFX works very differently and uses a special script language for the assembly of components. So you would need a good understanding of it in order to create your own elements.
We have a custom connector training that could help out:
https://dl.buw-soft.de/afx/guides/AFX_Custom_connector_training.zip
Here a documentation of the script language:
https://dl.buw-soft.de/afx/guides/AFX_Scriptlanguage_docu.zip
Hope this helps
Greetings Sam
Samuel Brantner
B&W Software GmbH
Hey Ben - We have some tools that can help with this. Give me a call if you're interested in learning more.
On this topic, PTC have just rolled out this functionality in Onshape.
What's New 1.157 - Frame End Caps
