Lathe idea of Creo-NC (Unable to copy the parameter values when spindle set up to "CONST_SFM ")
mrao
Dear all,
We have set up cutting parameters(Feed, Speed and Radial Depth) in “cut data” window. But the speed couldn’t automatically import to parameter window of lathing sequence. This means the “CONST_SFM” function couldn’t use, it doesn’t make sense to me. Sometime lathing big diameter of work piece, sometime lathing small diameter of work piece, so that, the lathing tracks are different. This means that we need to create a lot of tool parameters according to their diameters.
Lathe machine usually used “CONST_SFM” (G96 and G50 code) on spindle speed, so that, I hope PTC can solve it on new version.
BTW, the Feed and Radial Depth can automatically import to parameter window.
Have a nice day!!
Mark Rao
0 REPLIES 0
