Does any one know how to use the loop option that is present in draft command?
Thanks...!!!
You need to select a surface. I recall that Creo will not initially highlight any edges, but when you select Next it will highlight a loop. If that's the loop you want, then click OK or Accept. Continuing to select Next will cycle through the available loops until it restarts; you can use Previous if it goes by one you want to go the other way in the sequence of loops.
