Merge only selected edge of surface/convert inner quilt edge to outer
joojaa
11-Garnet
For reasons of convenience I would like to have a closed surface where one of the edges is open in Creo Parametric. A simple example could be a surface of revolution that is swept 360 degrees but has a open edge where the surfaces meet. Below is a artificially created image, where the sweep angle is close to but not exactly 360 degrees.
Revolved surface with open edge (but not quite closed)Revolved surface with open edge (but not quite closed)
So i am wondering is there:
  1. A way to split a self enclosed surface at one and only one edge?
  2. A way to merge only said edge and not all edges?
  3. Convert inner edge to outer edge?
This would be handy at times.
tbraxton
(To:joojaa)
Is this what you need? The cone is split and then flattened (yellow). Creo 9 model enclosed for reference.
Involute Development, LLC
Consulting Engineers
tbraxton
(To:joojaa)
Divide surface which is available in Creo 9+ as a core modelling feature. Depending on what you are attempting to do subsequent to this it may provide a solution.
About Divide Surface (ptc.com)
Example Creo 9 part enclosed.
Just note ...
Resulting quilt is still divided into 2 pieces.
Martin Hanák
joojaa
11-Garnet
(To:tbraxton)
No this does not work the edge is still a inner quilt edge i want to open the surface so it no longer wraps around. This was the first thing i tested. Think of me wanting to do something like edge rip in sheet metal mode but on a surface with no thickness. So in essence i want to draw a circle that is not connected on one side.
tbraxton
(To:joojaa)
joojaa
11-Garnet
(To:tbraxton)
That is a good workaround, even though it only solves 2/3 of my problems*. Although i don't want to flatten the quilt.
Would be nice for usability if the Flatten quilt would allow you to specify a seam. Likewise that sweep could be disabled from merging closed loops for certain usecases.
* I ended up using a variation of this where i merge the part instead of trim
