ModelCHECK PARAMCHECK configuration question
Trying to set up ModelCHECK to add missing parameters to models that were not derived from our templates using the PARAMCHECK option in the .mch file. Works pretty well except I can't configure it to add a blank parameter. The best configuration I have now is to add a space to each missing parameter after the initial interactive check is done. Typical start file entry: PRT_PARAMETER MATERIAL STR. If ten parameters are missing the user has to enter a space for each and then click the Add button. Looking for any solution to avoid entering a space for each parameter. Just click the Add button and you're done. Any suggestions?
--Kirk Wemple
