Dear Fellow Community Members, Please help me on this topic. I had created a BOM Table with Multiple Rept Region, But it is not Functioning Properly. Some regions are working fine but, some like Part Name, QTY are not working. Please suggest some work around or corrections.
Thanks in advance
Why separate repeat regions? I don't think you can add user text unless you define a comment region?
Use one region and define required columns with a comments command in the repeat region.
unfortunately your pictures are not readable -AND- you did not describe properly your problem.
I had applied rept region in first two columns then for QTY then material, then surface area and at last total weight and other fields will be filled manually by user.
It shows results for surface area and mass, but not for other regions.
