Pro/program to suppress specific extrude based on dimension value.
brianlynn
I have an "Extrude 38" that I want to suppress when d2839 exceeds a value
of .865, but it has been so long since I played in pro/program, I do not
really have the time to fiddle with it to relearn what to do. Can someone
tell me how to code pro/program to get what I want.
Thank you,
Brian S. Lynn
Technical Coordinator, Product Engineering
1 REPLY 1
Hi Brian
Today by a google search I found this really old topic, so my answer will help a lot somebody else
1. Open ProProgram
2. Find the proper line where your feature "Extrude 38" is described
3. Type IF d2839 > .865 in the line above ADD FEATURE...
4. Type END IF in the line underneath END ADD
Regards
