I'd like to make good use of CreoView using PVZ & EDZ files but I must be missing some setup information.
When I first open a pvz in CreoView all the geometry is turned off. I have to select a checkbox in the model tree to view it. I'd like the model to be visible by default. Is there a setting for that?
Also... I'd like to be able to use "Combined States" in order to establish defined views.
I discovered that there is a "Recipe File" (export_pvs.rcp) that requires "adapter/outputAuthorState=" be set to 1, otherwise it does not show Combined States at all.
But when I do that the geometry is not visible. The Tree is populated but I can not view any of the parts...
What am I missing?
Check for filters in Creo View.. and turn on the Model Geometry filters..
To Auto load the Creo view data, There is an enhancement, Set "Autoload All files" for Loading under File Options > General > Loading
For Combined states, Output Author stets needs to be Checked (set 1 when in txt editor. )
Thanks... that's helpful!
One more issue though... I don't know why but my PVZ no longer shows any geometry! The annotation is visible and the parts show up in the tree but model space has no geometry.
Excellent!
Thank you so much!!!
