Save tree filter settings
ptc-5974501
This is to expand on the post already out there:
http://communities.ptc.com/message/12622
What I want to do, is save the Tree Filter -> Display settings, so I don't have to do this for every part and for every open. It looks like there's a "mdl_tree_cfg_file" option in the Options -> Configuration Editor, but does this really continually reference a specific Creo file? That doesn't seem like it would work so well with Intralink. Anyone know how to save these settings?
6 REPLIES 6
That first link is correct. I'll try to spell it out here for future searchers.
In the Model Tree Settings dropdown, first set the Tree FIlters and other options as desired.
Then, in the Model Tree Settings dropdown, select Save Settings File. Save this file somewhere. I saved it with the config file.
Go to File -> Options -> Configuration Editor. Add the mdl_tree_cfg_file Option Name with your previous settings file as the Option Value. All set!
When I do this I get this error. What's it not seeing?
StephenW
(To:rmckibben)
ehhh, 60 errors, you're good..  Sorry, bad joke.
If you look at the errors, the file you are reading has extrude, dtm3, hole, dtm4, etc. Honestly it looks like the export of the "text" of the model tree instead of the exporting the settings.
Export the settings again using
My model tree settings file looks like this:
!Creo Parametric cfg file Version No. 1
!Creo  TM  2.0  (c) 2015 by PTC Inc.  All Rights Reserved.
COLUMN "Info" "Status" 4
COLUMN "Info" "Feat #" 3
COLUMN "Mass Properties Params" "PRO_MP_MASS" 5
COLUMN "Mass Properties Params" "PRO_MP_DENSITY" 4
COLUMN "Info" "Feat ID" 5
COLUMN "Simplified Reps" "Current Rep" 9
SUPPRESSED    ON
EXCLUDED    ON
FEATURES    ON
MFG_OWNER    ON
NOTES    ON
BLANKED    ON
INCOMPLETE    ON
COMPS    ON
BT_BODY_CONNS    ON
BT_INCOMING_CONNS    ON
BT_BODY_CONTS    ON
BT_MOTION_AXES    ON
ENVELOPE    ON
COMP_PLACEMENT    ON
GEOM_BACKUPS    ON
MECH_STR    ON
MECH_THR    ON
MOLD_OWNER    ON
SECTIONS    ON
Yeah, that was it. I was saving the Model Tree instead of the Setting file. Thanks.
Gagan
(To:ptc-5974501)
Hello Jeremy
Fist save the setting file , the name of the file will be tree.cfg , save to some location , you can import this every time when ever you need this settings , Or you want want this sitting file to load by default on creo startup. you have to make some changes in the config.pro file
Give the tree.cfg File path to the value mdl_tree_cfg_file.
Regards
