If You prefere -for any reason- to work with a fixed plane size, a switch to be set in the plane generating menu to 'Reuse Size of Def Planes' versus 'Calculate Size acc. to Component Size' would avoid to be urged to adjust plane size every time You create a new plane. The setting should be arranged in the start files and be passed on to newly generated components.
It would be helpful for instance in a case that You want skeleton-planes maintaining constant size within one assembly level, but could alter size on different assembly-levels.
Hi, is this a Product Idea (formerly an Enhancement Request)?
