Does Creo have a weld symbol for stud welds? If so where is it located? I have looked in the weld application under spot weld but I do not see anything.
I have encountered the same issue.
I need to create a welding feature for a stud bolt, but using the feature in the welding environment, I am unable to achieve the correct symbol, which according to the standard should be like the one attached.
I am also waiting for feedback on this topic.
Alberto
