Tangency lines not showing in a drawing view
mpeterson
Hello group,
I am having a problem with tangency lines not showing in an assembly drawing when the view is no hidden lines. In the same drawing I get a view where a portion of a section view is blank too. I have seen this behavior before, but I never found the fix because it was not critical for that particular drawing. This same drawing looked fine before I made some geometry changesand alsochanging the accuracy for some of the parts. Attached is an image showing the partial blanked out area of a section view. Any suggestions will be greatlyappreciated.
Sincerely,
Mark A. Peterson
Design Engineer
Varel International
Hi Mark,
Have your geometry changes resulted in an interference condition between
two parts? This causes ProE to interpret hidden lines incorrectly - it
may also be affecting the tangent lines in your case.
Mark von Huben
Principal Mechanical Engineer
Cochlear Ltd
1 University Ave
Macquarie Park, NSW, 2113
Australia
p +61 2 9425 5210
dgallup
(To:mpeterson)
Sections can fail when there is a surface coplanar with the cutting plane. Sometimes a curved surface tangent to the cutting plane too. Try moving the cutting plane slightly.
In Reply to Mark Peterson:
Hello group,
Sincerely,
Mark A. Peterson
Design Engineer
Varel International
PTC quality philosophy: We've upped our quality standards. Up yours.
