USE NOTE FRAMED ON 2 (Creo 10.0.3)
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Notify Moderator
I should know is it possible to frame a note with a single frame on 2D model when you want to write on many lines like this screenshot. Because actually I just do frame each line only but not all the lines together.
Thanks for your help if you can give me tips.
- Labels:
2D Drawing
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
You are in the wrong forum.
PTC has two CAD systems: Creo+ and Creo Parametric and Creo Elements Direct.
Which makes it confusing.
More, for Creo Elements Direct:
- The 3D software name is Modeling, and
- The 2D software name is Drafting.
For Creo+ and Creo Parametric, use only this tab:
You should move your post to this community to have a better chance to get an answer.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
That's true. Is it possible to change topic category ?
Thanks.
Regards
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
I do not think so. Either you delete and recreate one or ask the moderator.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
Hi @Alex_B.92350,
Thank you for your question.
Your post appears well documented but has not yet received any answers. I am replying to raise awareness. Hopefully, another community member will be able to help.
Best regards,
PTC Community Moderator
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
I think you are attempting to enclose multiple lines of a note inside a box?
(from another post)
It sure seems that this isn't possible. Please suggest a product enhancement idea.
