USE NOTE FRAMED ON 2 (Creo 10.0.3)
Alex_B.92350
7-Bedrock
I should know is it possible to frame a note with a single frame on 2D model when you want to write on many lines like this screenshot. Because actually I just do frame each line only but not all the lines together.
Thanks for your help if you can give me tips.
5 REPLIES 5
You are in the wrong forum.
PTC has two CAD systems:    Creo+ and Creo Parametric    and     Creo Elements Direct.
Which makes it confusing.
More, for Creo Elements Direct:
- The 3D software name is Modeling, and
- The 2D software name is Drafting.
For Creo+ and Creo Parametric, use only this tab:
You should move your post to this community to have a better chance to get an answer.
http://kotom.eng.free.fr
That's true. Is it possible to change topic category ?
Thanks.
Regards
I do not think so. Either you delete and recreate one or ask the moderator.
Hi @Alex_B.92350,
Thank you for your question.
Your post appears well documented but has not yet received any answers. I am replying to raise awareness. Hopefully, another community member will be able to help.
Best regards,
Catalina
PTC Community Moderator
PTC
pausob
(To:Alex_B.92350)
I think you are attempting to enclose multiple lines of a note inside a box?
(from another post)
It sure seems that this isn't possible.  Please suggest a product enhancement idea.
