In solidworks dimension are aligned correctly but @creo making some miss alignment
below attached screen shot from solid works
this is creo
You can make product improvement suggestions here https://community.ptc.com/t5/Creo-Parametric-Ideas/idb-p/creoparametric
please ask PTC Support. They will tell you whether requested functionality is implemented.
I asked, they said its not possible. Maybe we can suggest to ptc team to implement in next version
