VERSION DIFFERENCES IN CREO PARAMETRIC
SJ_10508956
Hello All, Greetings!
We have a peculiar scenario in which a command or set of commands work in one version of Creo Parametric but does not work in the other.
Solidify does not work in a direct manner on an offset surface/quilt in Version 11.0.1.0 but works straightaway in Version 11.0.5.0 by selecting the surface and it finishes the task!...I wish to know what made this difference. Are there a few patches installed in the later version, I mean.
How can we know what is the difference between the two versions? Where can I find this information? I will appreciate if someone can please provide guidance.
Thanks a ton.
7 REPLIES 7
StephenW
(To:SJ_10508956)
SJ_10508956
(To:StephenW)
Thank you Stephen. Bless you!
StephenW
(To:SJ_10508956)
Generally speaking, the version releases are bug fixes, although there are occassionally some major enhancements that are just a little behind and don't get introduced in major releases and get added in one of the version releases.
In your specific question, this looks like it would be a bug fix.
SJ_10508956
(To:StephenW)
Thanks again.
my basic rule regarding the version of Creo installed on computers in one design group ... all users must use the same version!
If a problem occurs and is fixed in a later version, then all users must upgrade to that version.
Martin Hanák
I agree and wanted the same but this has been a unique situation. Thank you very much. Bless you!
Hi @SJ_10508956
If so, please mark the appropriate reply as the Accepted Solution or please feel free to detail in a reply what has helped you and mark it as the Accepted Solution. It will help other members who may have the same question.
Catalina
PTC Community Moderator
PTC
