Community Tip - Did you get an answer that solved your problem? Please mark it as an Accepted Solution so others with the same problem can find the answer easily.
X
* mobile: * web: www.mccloskeyinternational.com This thread is inactive and closed by the PTC Community Management Team. If you would like to provide a reply and re-open this thread, please notify the moderator and reference the thread. You may also use "Start a topic" button to ask a new question. Please be sure to include what version of the PTC product you are using so another community member knowledgeable about your version may be able to assist.
I have searched the help files and came up with zilch. Does anyone know of a way to show the sheetmetal K-Factor in a parameter on a drawing? Parametrically that is.... I don't want to have to manually enter it in, but get it from the model automatically. - marc
