Witness line display
John.Pryal
Hi all,
is there a way to create a dimension show in the attached sketch. I want to remove the horizontal witness line between the 2 vertical witness lines.
John
9 REPLIES 9
John
If you double click the dimension the dimension properties window opens, on the second tabpage in the right undercorner you find the whitnessline display.
I never needed it but I think you can solve your problem that way.
Chris
Hi
I just tried it and I think it can't be done.
If there was a third option in the left site for: display/configuration/linear or center leader. I might be possible.
You should try to find out how to write a new line in your configuration.
Sorry I can not help you there, maybe someone else.
Chris
John.Pryal
(To:chris5)
Well thank you for trying Christiaan.
John
You can flip the arrows using RMB-Flip arrows to remove the in between witness line.
Hi
What version do you use? I've tried it in WF5 and it does not work.
Or is there something more?
Chris
Check your drawing option setting for text_orientation. If it's set to anything other than horizontal you will get that line. I'm not sure any of the other options have an affect on it.
chris5
(To:Kevin)
Hi Kevin,
With me it is set to: "parallel", and I do not have that option to delete that line.
I do not want to change that or my dimensions want be parallel to diametrical dimensions.
Is there another way?
Chris
Kevin
(To:chris5)
There is but it's going to be more trouble than it's worth especially if you have a lot of dimensions you need to do this to. Set the text_orientation value to horizontal. You can add a draft dimension and override the value so it's blank. Create a note with the model dimension (&d2 for example) and orient it so it is parallel to the dimension line. You can also do this with draft dimensions.
My guess as to why the options work the way they do is based on the drafting standards.
chris5
(To:Kevin)
Hi Kevin,
For me this answer is solved. I hope it is for John too.
Thanks I did it that way when needed. Lucky me that does not happen much.
Chris
