hi,
i am trying to add &todays_date in drawing sheet but the date is not showing instead of it shows only &todays_date
Edit the note and just add a space after it or just hit enter.
As a side note, "specified" is spelled wrong.
If you are in the format (.frm) file, it only shows the code.
If you are in a drawing, it should show the date as expected.
@DR_6962550 wrote:
its same as the note not showing date
your picture is not descriptive enough.
Please replay uploaded video.
i did it as you did in drawing file mode it shows only date and year. the month is not showing what to do?
please read
https://community.ptc.com/t5/Creo-Modeling-Questions/quot-todays-date-quot/td-p/82698
for me its worked thank you
