annotate on cylinder surface failure
IZ_8255117
I am using Creo Parametric Release 4.0 and DatecodeM150
Creo 4.0 M150 could not annotate on cylinder surface , even the selection pass, dimension won't be generated
while same action on Creo 4.0 M110 is passed
Here are the errors that I faced
no error but just return that the selection is invalid and can not continue
2 REPLIES 2
@IZ_8255117 wrote:
... Here are the errors that I faced
no error but just return that the selection is invalid and can not continue...
Could you please provide a screenshot of this warning?
IZ_8255117
(To:VladimirN)
see above please, select surface, can not continue
