Cross section cutting lines don't display correctly
  • September 21, 2022
  • 4082 views
I am using Creo Parametric - Release 8.0 (connected) Release 8.0 and Datecode8.0.5.0
Cross section cutting lines don't appear correctly when exporting PDF. The dots and dashes look too short.
This is what I'm getting https://drive.google.com/file/d/12AUXgavN0PHAdR7DDriC-8zjtaAcv0zH/view?usp=sharing
This is the desired result https://drive.google.com/file/d/1_FPd2YIHyBwxyVX0UdCaJEMIEKQC_e9J/view?usp=sharing
Best answer by MartinHanak
@AW_10407897 wrote:
Hi Martin,
Unfortunately. Creo 3.0 and its files are no longer accessible after the upgrade. All I have left is the old PDFs (which look identical in all respects except the length of the section line dashes).
add new option into your drawing - see picture. The value in inches represents the length of line segment.
line_style_length PHANTOMFONT 1.00000
please pack your model+drawing into zip file and upload it. This enable other users to investigate your problem.
Hello, please see attached a zip file with an example model and the PDF output showing the problem.
I am sending some information...
1.] Settings inside your drawing cause that cutting line and visible geometry edges are displayed using the same color, the name of this color is Geometry.
2.] By default Geometry color is drawn by pen 1. I uploaded 3 examples of pen 1 width.
My pentable is also uploaded (packed in zip file).
My config.pro contains following options:
use_8_plotter_pens yes
pen_table_file E:\users\creo7_parametric\pentable.pnt
pdf_use_pentable YES
