I am using Creo Parametric Release 4.0 and DatecodeM150
annotate on cylinder surface failure
Creo 4.0 M150 could not annotate on cylinder surface , even the selection pass, dimension won't be generated
while same action on Creo 4.0 M110 is passed
no error but just return that the selection is invalid and can not continue
@IZ_8255117 wrote:
... Here are the errors that I faced
no error but just return that the selection is invalid and can not continue...
Could you please provide a screenshot of this warning?
see above please, select surface, can not continue
