axis and control axis length in 2d creo 3.0
Redro
Hello
i drawn a rectangle , how i put middle axis (orizontal and vertical) ,
i put in 3d but in 2d not see this
i put axis with sketch but i do not control dimension on it ? it's a tips and tricks for this
tks for response
kdirth
(To:Redro)
One method is to put diagonal contruction lines through rectangle in the sketch and place datum point at intersection. When extruded it creates a centerline. this can then be shown in the 2D.
3 REPLIES 3
DonSenchuk
(To:Redro)
Use 'Show Model Annotations' to show the axis in your drawing (2d). It will be the 'model datums' tab within the Show Model Annotations window.
i don't find the axis but it is a circle you are right
kdirth
(To:Redro)
