controll of assembly components using relation
Not applicable
Hi All, I want to controll an assembly of 2 components using relations.Both are family instances; 15,20 etc. I mean,if i specify 15(defined parameter), both the components have to changed to same size ie. 15 NB. I may sound weired but is it possible and if yes please share your knowlodge. Regards Vishal
mhanak2
6-Contributor
(To:)
Thanks,but is it possible by using parameters???? regrads vishal
Vishal, It's relatively easy to do this with straight relations; your mixture of relations and family table calls is not readily doable. Using just Relations you can do a couple of things. For example, in the Assembly set up a Parameter called LENGTH. Now go to Relations, pick one of your parts to Edit and establish a relation by picking on the dimension and writing something like "d2:2=LENGTH". The ":2" is the key; it's an ID unique to a particular component in the assembly. Similarly, you could also set up a Parameter in the part called LENGTH, then in the assembly write "LENGTH:2=LENGTH". The 1st LENGTH is the one in the part; the 2nd is the one in the assembly. David
