how to insert component index into note or dimension
MichalLukac
8-Gravel
is there any way how to insert index of specific part from repeat region (rpt.index) into note in drawing?
I work in creo 3
thanks for advice.
6 REPLIES 6
Michael,
Not an option, you can vote exiting Idea submitted for the same Refer to rpt.index in a note or symbol.
Hi ok,
But may be stupid question.. How to vote? I don't see any button for voting in that topic....
Good day Michal,
It appears you may not have an active maintenance contract with PTC; please see this discussion for more information.
Best,
Toby
Hello, ok maybe this is the problem, I'll ask my sys. admin for this...
thanks.
Toby Metcalf‌, why did this get moved to Community Help?  Yes he ended up with questions about voting but this was first and foremost a Creo Parametric question.
LinkedIn
Hi Doug,
You are correct, it is a Creo question; it has been returned to the Creo space.
Best,
Toby
