pro e 4.0
ptc-4179203
pro e 4.0
hai friends.
I want to know how can we assemble a component in assembly in certain angle with respect to other line or axis. also how can we select a reference while rotating a component after aligning any axis. please help me in this regard.
Constantin
(To:ptc-4179203)
Hello Bhagyaraj,
the angle constraint only works with planes surfaces (and a rotation axis or line)
Another way would be to use a curve skeleton (e.g. sketch) onto which to assamble the components. The angle control would then take place in the skeleton part.
Hello Bhagyaraj.
As constantin already mentioned angle constraint works with planes and surfaces. you can use find option to search for the planes to align, while rotating the parts.
