template file path for importing step/iges file
ssreevalsan
8-Gravel
I am trying to open a STEP file using a template, as shown in the attached image.
It works fine initially, but if I close Creo and reopen it, the template file changes. Could you please suggest a solution?
The default import templates are set by the template_designasm and template_solidpart config.pro settings. However, keep in mind that this also changes the default templates that are selected when you select File New. You may wish to set force_new_file_options_dialog to YES to force users to pick an appropriate template in the File New menu.
3 REPLIES 3
thank you for your support
It will always revert to the file specified in your config file when you restart Creo.  To make a permanent change you will need to update your config.pro.
