The default import templates are set by the template_designasm and template_solidpart config.pro settings. However, keep in mind that this also changes the default templates that are selected when you select File New. You may wish to set force_new_file_options_dialog to YES to force users to pick an appropriate template in the File New menu.
Enter your E-mail address. We'll send you an e-mail with instructions to reset your password.
