Hi! i've installed creo view express but i can't get it to work, i dont get any error message, it just does not open.
You can also contact PTC Support if you are active Creo customer.
do you have Windows operating system installed?
Look into Event Viewer. Maybe you will find error message.
I do get an error on event viewer, and theres a resolution on Article - CS302448, but it's for older versions, i've tried it anyways, but with no success.
I've tried in 4 different laptops, same thing on all of them.
how did you set PVIEW_LANG=en ?
On https://support.ptc.com/help/creo/view/r9.0/en/index.html#page/creo_view/install_config_guide/Starting_Creo_View_and_Modifying_an_Installation.html I found this ... try setting PRO_LANG=english, too,
i found my mistake, i was adding the variable in the user variable instead of the system variables.
