Hi! i've installed creo view express but i can't get it to work, i dont get any error message, it just does not open.
You can also contact PTC Support if you are active Creo customer.
do you have Windows operating system installed?
Look into Event Viewer. Maybe you will find error message.
I do get an error on event viewer, and theres a resolution on Article - CS302448, but it's for older versions, i've tried it anyways, but with no success.
I've tried in 4 different laptops, same thing on all of them.
how did you set PVIEW_LANG=en ?
On https://support.ptc.com/help/creo/view/r9.0/en/index.html#page/creo_view/install_config_guide/Starting_Creo_View_and_Modifying_an_Installation.html I found this ... try setting PRO_LANG=english, too,
i found my mistake, i was adding the variable in the user variable instead of the system variables.
Hello, can you help me? Im having the same problem that you did, how do you ended up solving it?
I guess @JAntunes set environment variable PVIEW_LANG on system level and assign it value en.
https://www.ptc.com/en/support/article/CS96862
How can i set this PVIEW_LANG?
Where?
Where?
what about to ask Google ...
https://www.google.com/search?q=windows+how+to+set+environment+variable
Thanks, but there was no need to be rude.
I'm not being rude, I'm just trying to help you.
