Hello everyone,
I am having problems with a mechanism analysis in Creo.
I have a square sliding pin that moves along an axis using a prismatic joint.
The pin is preloaded by a spring.
An eccentric rotating disk (cam) pushes the pin upward, and the spring pushes it back when the cam rotates away.
The disk does not rotate around its geometric center (offset axis).
I need to evaluate the required driving torque of the rotating disk during the mechanism analysis.
3D surface-to-surface contact between cam and pin
Cam / curve follower definition instead of contact
Unfortunately, both approaches fail during the mechanism analysis with a “simulation failed / analysis failed” error.
I also need to place 48 identical sliding pins into corresponding grooves/slots around the disk.
Is there a way to automatically insert or pattern these pins without defining each pin manually in the mechanism?
Creo version: 12.4.0.0
Any help or best practices would be greatly appreciated.
