It appears after having set up the config file for the parameter dialog it does not sort the name column descending. The XML does contain the lines:
<sortby>
<column name="name" order="Descend"/>
</sortby>
The other settings function as expected. Something missing? Expectations too high?
I tested your xml file in CR3 M130 and realized that there is bug in Creo. See following "table":
<column name="name" order="Ascend"/>... without sorting
<column name="name" order="Descend"/> ... ascending sorting
<column name="name" order="None"/> ... descending sorting
This means if you want to sort parameters in descending order, you have to set following option in XML file:
Please report the problem to PTC Support.
1.) According to https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS134639, you have to set config.pro option ‘parameter_dialog_setup_file’ and browse to ‘rp_config.xml’ as a value
2.) If I remember it well, Creo saves into ‘rp_config.xml’ only changes made to default dialog setting.
3.) I can test your problem, if you tell me what Creo version you use (for example Creo 3.0 M090).
I forgot to mention I am using Creo 3 M130. Attached is the XML saved by Creo that I compared to other ones saved with visible differences in settings made. Thank you for your time.
-Michael
I appreciate you checking this out and concur with your results. I have tested it further in all modes and will report this to PTC.
| Mode | Sort by | Param Edit | Rels Edit |
| PRT | None | descend | none |
| ASM | None | descend | ascend |
| DRW | None | descend | ascend |
| PRT | Ascend | none | none |
| ASM | Ascend | none | ascend |
| DRW | Ascend | none | none |
| PRT | Descend | ascend | none |
| ASM | Descend | ascend | ascend |
| DRW | Descend | ascend | ascend |
Relation editor in DRW mode was for an assembly.
Your response will be marked as accepted. Thank you for your efforts,
-Michael
Anyone know if this issue is already solved? (maybe link to case details?)
WOW I let this one fall by the wayside. I have checked this behavior in both Creo 4 M070 and Creo 5.0.1.0 and it checks out the same as in the table I posted earlier. I will open a case and report back when I get an SPR#.
I opened a case with PTC and they have responded: "This issue has been reported to R&D as SPR 7845450, as this is not impacting business critically, SPR is submitted with medium severity." . I feel badly for not reporting this earlier as I am sure the issue would have been resolved by now. I will look for this to be fixed in a later build or release of Creo.
In a message from PTC Tech Supt I was told this issue has been corrected in Creo 4 M090. There was no mention of what maintenance build of 5 or 6 it is resolved in. Case closed.
