disable Windchill integration on Creo Simulate
AR
7-Bedrock
7-Bedrock
is it possible to disable Windchill integration on Creo Simulate.
I would like to use it outside of windchill
MartinHanak
24-Ruby II
(To:AR)
@AR wrote:
However, if I also use Creo Elemnts Direct Modeling, in the latter I have to put the windchill server back online every time!
And if I put it online in the workgroup manager, it is also online on Creo Simulate
find Creo Simulate startup file (file with psf extension) and add line similar to the following one at the end of file.
ENV=PTC_WF_ROOT=C:\PTC\Simulate_WF_ROOT
I hope this setting can separate Creo Simulate from Creo Elemnts Direct Modeling.
Martin Hanák
6 REPLIES 6
BenLoosli
(To:AR)
Should be able to by putting Windchill offline to your Creo session and working out of a disk work location.
AR
7-Bedrock
7-Bedrock
(To:BenLoosli)
MartinHanak
24-Ruby II
(To:AR)
Martin Hanák
AR
7-Bedrock
7-Bedrock
(To:MartinHanak)
It seems to work .....
I left your string even though Creo Simulate is installed on another folder ... okay?
MartinHanak
24-Ruby II
(To:AR)
YES that is OK.
FYI ... PTC_WF_ROOT variable specifies path to directory where Creo Simulate saves user "settings".
Martin Hanák
AR
7-Bedrock
7-Bedrock
(To:MartinHanak)
Perfect, by editing the simulate.psf file
adding the line:
ENV = PTC_WF_ROOT = C: \ tmp \ Simulate_WF_ROOT
