by
unknown1
283
Views
| Below you will find the agenda for the next Users Meeting. Those of you
who were at the last meeting...
283
Views
247
Views
276
Views
I am unable to create a angular dim under 1°. Is there a setting that
needs to be added/changed? ...
352
Views
1114
Views
| As we impatiently wait for our CAD admin to get this new rendering
extension from PTC, I thought I w...
1114
Views
Thank you for the replies. I have received the following answers:
314
Views
1 Reply
535
Views
| Is there a method whereby an Excel spreedsheet can drive a parametrized
proe model.
1 Reply
535
Views
http://www.profilesmagazine.com/p22/tips_muirhead.html Lee
lbirch@maytag.com
260
Views
proe 3d model. Thanks
363
Views
Does anyone have an equation to create a helical curve based on helix
angle? I will gather all the e...
357
Views
Hi everyone, I know this would never be supported by PTC but I have a
need to edit the UGC head of t...
348
Views
Try the McMaster-Carr catalog at http://www.mcmaster.com/. Many of their
fasteners are downloadable ...
358
Views
Does anyone have, or know where I can find examples of "IF THEN ELSE"
stuff? I need to do some thing...
272
Views
by
abush
389
Views
| I guess I overlooked using copy/paste. That gets me all the tables and
draft entities that I can mov...
389
Views
Good Morning, Wildfire 2.0 - I'm customizing my standard hole files. The
problem is this...I want to...
327
Views
by
donald_gibson
1 Reply
755
Views
| Hi everyone, I need to make a program that will go something like this:
IF OD >= 2 AND OD < 3 D6=.5 ...
1 Reply
755
Views
by
JeffVoegele
1 Reply
516
Views
| Hi, Has anyone used the right angle head functionality yet in a real
world environment? How's it wor...
1 Reply
516
Views
Trying to create a curve using 2 or 3 edges of a square. Works for 1 or
all edges. When I pick 2 or ...
297
Views
by
unknown1
1 Reply
715
Views
| Is there a command (symbol) to get text in a note to underline? Ron
1 Reply
715
Views
Hello again everyone, How do I set the default background color in WF-s
to be the same as 2001. I kn...
322
Views
In wildfire 2 when you measure a distance it now only gives you the
actual distance, where as before...
274
Views
This may be a tough to explain, but here goes: When trying to create a
closed corner, as explained i...
493
Views
1 Reply
564
Views
| Anyone know of a good source to get some textures?? I need a
thermoplastic elastomer (Santoprene) te...
1 Reply
564
Views
by
abesau1
334
Views
| Where do I set the default font used to display the simplified rep name
(SIMPLFD REP: XXXX_XXXX) and...
334
Views
http://www.arabnews.com/?page=1§ion=0&article=62075&d=14&m=4&y=2005&pix=kingdom.jpg&category=Kingd...
450
Views
Does anyone out there in ProE land know how to make Datums created
on-the-fly in 2001 to useable Dat...
358
Views
anybody passing data between pro/engineer and matlab? if so, can you
provide a 10,000ft overview of ...
544
Views
test Damián Castillo MCAD Administrator Pro Engineer Consultant
Hensley Industries 972-406-4788
330
Views
269
Views
Everyone, Is there a parameter setting that would allow me to always
have the first pass of a volume...
322
Views
| Subject | Author |
