Check out this video on Creo Composites from PTC Application Engineers
Presenters: Lee Goodwin (Technical Specialist, Principal) and Ryan Butcher (Technical Specialist, Fellow)
Original Date Presented: August 15,, 2023
To dive deeper into the subject, check out Creo Composites Learning.
WEBCAST Q&A
Question from David: In this model, is the center stiffener ply hollow or solid?
Answer: Typically they are a honeycomb that has some drape.
WEBCAST Q&A
Question from Paul: Does simulate calculate for first ply to failure?
Answer: Once the composite feature is created, you can use any of Creo's simulation tools just as you normally would.
Great Video. Is it helpful for tyre design
@kamleshjoshi We haven't made any special functions for tyres to date but we do have some customers exploring that possibility.
