Auxiliary Application with ProE
JD_2779181
Hi guys,
I have a DLL Application that is launched when Creo starts, when I go to auxiliary application menu, and I stop it, it stops. No problem until here. But when I try to start it now, it crashes Creo.
I have no idea why, nothing in the trail and traceback.
Can you help me figure it out please? Thank you
FabianWolf
(To:JD_2779181)
If you're using Visual Studio as IDE you can simply attach the debugger to the xtop.exe process just before you restart your application and add a break point at the beginning of your user_initialize() function. When starting the app, the debugger will jump into it and you can check step by step which areas of your code get executed until the crash occurs.
FabianWolf
(To:JD_2779181)
Thank you! It helps me 🙂
