Can someone help in writing code to add action listener on Model Save
SD_10158207
7-Bedrock
Hello Everyone,
I am developing a J-Link tool the requirement is to execute the tool on every save of the model.
I have implemented this on session objection performing session.AddActionListener but this is resulting into clearing undo/redo stack into session.
Looking for better option to keep the track on undo\redo stack and tool should run on every model save.
Thanks in advance
Swapnil
remy
(To:SD_10158207)
Hi this is a known and general limitation. This applies to Toolkit hence to Java OTK : https://www.ptc.com/en/support/article/CS143895
and not only to listeners but also to the whole API.
If I skip the session action listeners it maintains the undo/redo stack. As soon I add Action Listener to session it clears the stack. Much appreciated help if someone provide sample code to add model action listener to on after active model save
remy
(To:SD_10158207)
please find a generic article with a code sample : https://www.ptc.com/en/support/article/CS316823
the code enables to catch the event when creating a parameter.
Have it run first successfully and then iterate it to your likings.
//edit the example above is Toolkit. Apologies.
here is an article about Java Object Toolkit (JOTK aka Jlink) code : https://www.ptc.com/en/support/article/CS408439
look into it and derive from it.
Hello @SD_10158207,
It looks like you have a response from our support expert. If it helped to answer your question please mark the reply as the Accepted Solution.
Vivek N.
Community Moderation Team.
