Creo Hide Dialog using C++ Object Toolkit and Close button
gpytel
2-Explorer
1. How can I show and hide dialog using C++ Creo Object Toolkit? I have designed a dialog using UI styler and wrote corresponding class to cover all buttons etc. How to do a hide a dialog/show?
2. In the creo dialog designer I selected "HasCloseButton" attriute to true. I am creating modal dialogs (if this is important). However, if I run the dialogs, the close button never works. Should I implemented any additional listener to the dialogs to make close button working? At the moment I do not create separate listener class for dialogs....
1. I think you want to close it ?
uifcDialogExit(); would be your friend.
else you can use
uifcDialogFind("", "")->setVisible(false);
2. You need to implement the close action with
uifcDialogFind("", "")->AddActionListener();
else you  can use the ProToolkit alternative way:
ProUIDialogCloseActionSet(dialog, ui_closePanel, NULL);
Br,
Eike
Thank you Eike. I tried everything. As for me: uifcDialogExit works correctly, uifcDialogFind->setVisible does not work at all. I dont know why. Do you think I should contact former PTC support? And the third option: ProUIDialogCloseActionSet works as well.
Thank you for your assistance! Have a nice day!
