Creo TK/OTK - Resource Files Directory
Hi @ all,
the next question is about the resource directory of TK Apps.
So inside of TK / OTK manual I found this :
| • | <creo_loadpoint>\Common Files\<datecode>\text\resource |
| • | <Application text dir>\resource |
| • | <Application text dir>\<language>\resource |
The first and the third possible solution work like a charm. So we use the third atm. As thr third solution discribes we need the resource directory for every language we want to support. But in normal case the resources didn't change for languages. Only translation files changes. So we try to change to the second solution like:
text (blue are folders)
- toolkit.rbn file
- german
- - message files
- resource
- - all resource files
- - all images
- - german
- - - resource translation files
- usascii
- - message files
But this didn't work, he do not find the resources. But I think it should work like this (but are not sure enough to open a ticket ... so I ask here).
The good think on this solution would be that the 300 resource files don't need to be copied for all 10 languages. So we only need to deliver 300 files, not 3000.
Br,
and thanks,
see ya at PTC TC's : )
Eike
