Customizing the pop up/hover display of creo parametric model names in the graphics window...
ploney
Customizing the pop up/hover display of creo parametric model names in the graphics window to include an additional parameter such as Title or PTC_COMMON_NAME
Is this just straight up an enhancement or is there a current customization method freely available?
For example.    In my screenshot it shows:    SYNTAX -->ITEM:F#(FEAT TYPE):FILENAME
On Screen --> Edge:F5(IMPORT FEATURE):601301
I want to show the same plus an additional Parameter to the right of FILENAME such as PTC_COMMON_NAME as in my mockup (Green Box) below.
RPN
(To:ploney)
Hi, I like the idea, because sometimes the displayed information is useless and it is hard to recognize that this is the right thing you want to select. But as far I know, out of the box there is no way to customize this.
You may search the resource files if you find this message. Maybe there is a way to add specific parameters to be displayed.
