Debug sync dll
sureshkumar.chi
Debug sync dll
I cant debug a code.i have linked all protoolkit header files and libs to a source code(c#) and even if i hover over a toolkit function it shows its argument and return type. But still when i set a breakpoint to a callback function i get a message"The breakpoint will not currently be hit. No symbols have been "
<h1></h1>
Suresh
Suresh,
If you are debugging through Visual Studio.
Select Debug->Windows->Modules
See if your dll is being loaded and if it has Symbols Loaded message
If "No symbols loaded" message appears against your dll, check the
following.
Compiler Options should have "Program Database (/Zi)" selected.
Linker Options/Debugging should have "Yes(/DEBUG)" for "Generate Debug
Info" option.
If you are using makefile
Add /Zi or /ZI to compiler options.
Add /DEBUG to linker options.
Other than these, I am not aware of any reason why breakpoints should not
be hit.
Vinay
On 25 February 2013 16:08, suresh kumar <
> function i get a message "The breakpoint will not currently be hit. No
> symbols have been "
> Regards
> Suresh
Suresh,
I have had a similar issue when debugging with Visual Studio 2010. When attaching the debuggerto the xtop dll I had to change the value of <attach to:="> from "Automatic" to "Debug these code types" and check the option native. From then on the symbol were loaded.
Jan
Hi Jan,vinay
Jan i tried your idea but it still i m getting a message"The breakpoint will not currently be hit. No symbols have been ",i m also using vs 2010.
Vinay i m using make file i have added compiler and linker options but still i couldnt resolve it and pdb file was also not created.Please Find the attachment for the make file and see if i have added the compiler and linker options correctly.
Suresh
Hi
Sorry The pdb file is created but still i m unable debug.
suresh
